Removing Mushroomed Glow Plugs the easy way
Discussion in '1982-Present GM Diesel' started by BARRAZA, Sep 30, 2002.
  1. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    You guys that know 6.2's well probably aready know this but for the rest of us, a mushroomed glow plug can be removed without any special tools or removing the head. Just got the one I had out, its the first thing that has gone right so far. Remove the injector and unscrew the glow plug, then grab the glow plug with vise grips and bend it back and forth until it breaks off. Then use some hemostats or spring loaded tweezers to grab the end of the glow plug and pull it through its hole inside the prechamber. Twist it up and out. Not much space to work but it beats the hell out of removing a head!!
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Congrats must have been close to the front of the engine.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Another trick is to use a shopvac or other vacuum to suck the GP tip from the chamber. Just make sure you use a vacuum with a bag so you can make sure the broken piece did in fact get sucked out......
