REMOVING MY TOP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JERRY-DEE, Sep 18, 2001.
  1. JERRY-DEE
    JERRY-DEE Registered Member
    Sep 14, 2001
    19
    SANTA CRUZ, CA. 95062
    Who ever owned my Blazer before me put some kind off weather sealant around the edges of my top making it very hard to take the top off. Is there a solvent to loosen this up? Any ideas?
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I had the same problem with mine when I first bought it. I ended up using a string from a guitar (wire), looped it around a head bolt at both ends and a friend and I dragged it between the bed and shell, using the wire to lightly saw thru the foam tape between the two when necessary. It worked well, didn't leave any scratches because the edges are smooth but it did take two people and a bit of coordiantion between the two.
    What, Me Worry?
    <a target="_blank" href=http://www.echobit.com:81/k5/> The 'BEFORE' pictures</a>
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    I had a '77 K5 years ago where the previous owner did something along those same lines. I didn't want to use solvent or anything harsh in case it decided to eat my paint. I used a box cutter/razor knife and a wide putty knife to pry it up a little.
    - Alan
    '82 K10 Suburban Silverado (AKA U.S.S. Nimitz)
    Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut.
