removing old tint?
Discussion in 'The Garage' started by BowtieBlazer, Aug 19, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I remember there being a post about this some time back....can't remember some of the best mentioned proceedures...I figure find a loose end and tear...come back and scrape clean with flat razor....maybe use some alcohol/windex solution as an aid....
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Yep..you called it. Also rubbing alcohol takes the sticky flim off good /forums/images/icons/wink.gif
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Yep, that's about it. Home depot has some orange smelling grease and adhesive remover that kicks a$$ too. It makes really short work of the adhesive left from the tint.
    BIGJ
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    flat razor it as much as you can then use some hot/warm water with dishwashing liquid, just don't burn yourself. you'd be surprized how much the hot water alone takes care of it. had to do it to 3 cars now. dam CHP...
    ARQ.
  5. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    I have used hot water like the preveas post said and it worked very well. good luck /forums/images/icons/grin.gif
  6. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    I used a screwdriver and that sticker remover crap, man did I have a headache afterwards. It did clean it up pretty good though.
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    nobody else mentioned it but if you use a rasor to get one corner up and use a hair dryer to heat up the glue on the tint it will come off with minimal cleanup required.just hold it about 5 inches away and heat it with a sweeping motion almost like if you were spraypainting.i did this to a buddies car and he was amazed that this method worked so well.he had too many tickets for his tint so the last cop that pulled him over said he had to take it off.
  8. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Does anyone know if/how you can remove the factory rear window tint, it is the perforated kind (little holes punched out) The tint shop said that it cannot be removed and that I need new glass, WTF?
  9. BowtieBlazer
    Jul 15, 2001
    2,462
    mine looked almost factory wasn't bubbled or preferated....came off like nothing....worked the edges up with the flat razor, pulled with good pressure and it came off for the most part backing and all, a little alcohol and the flat razor took off what eccess glue it left behind....damn its wierd not having tint...it was onlike like 75% light blue tint but tomorrow the 2% goes on /forums/images/icons/grin.gif (insert evil laugh)....
  10. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    The factory perferated tint will not come off its little ceramic dots that are baked on just get a new backglass Their not that expensive
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, look closely at the back glass. It doesn't have a film glued to it. As Carl Sagan would have said, there are "billions and billions" of little tiny dots baked onto the glass. Maybe you can find someone nearby that will trade with you. If you were closer I would trade. That "tint" is very sturdy and won't scratch easily like the plastic films will. /forums/images/icons/cool.gif
