removing outer bushing shell from leaf springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coincidentally, May 23, 2002.
  1. coincidentally
    coincidentally Registered Member
    Apr 23, 2001
    53
    MA, USA
    I've recently got some greasable urethane bushings (from offroad design) and am trying to remove the stock bushings (the 3 piece rubber ones) I got the middle metal tube out, along with the rubber bushing, but I cant seem to get out the outer metal tube, its really stuck in there good.
    anyone have any tips?
  2. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i use a air chisel.try to get it started with a regular chisel,then hammer down.if you don't have a air chisel try a hacksaw and cut through it part way the use a regular chisel.you'll have to take the saw apart put the blade through the spring eye and then put it back together.you just need to cut it all the way through the outer metal tube and work the rest of the tube towards the center.you have to try to collapes it rather than push it all out at once.
  3. coincidentally
    Apr 23, 2001
    53
    MA, USA
    that seems like it would be pretty effective. Looks like I have something to do on saturday /forums/images/icons/smile.gif
    thanks for your help
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i used my saer saw. worked great. didnt mark up the spring holder ethier.
    grant
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I just did this today. I drilled out the rubber and punched the center tube out. Then I took a bushing cutter bit in my airchisel and cut the out metal tube. Then I used a regular air chisel bit to collapes the tube to the center a drove it out. Ran out of time so I'll do the shakels tomorrow and change the frame mounts to ORD shakel flips.
  6. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    I just did a ORD shackle flip and put in their greasable bushings on my truck. I torched the bushings out( which is dangerous as the inner sleeve pops out from the heat and with the hot melting rubber on it lands on your hand and sticks to it. Then you sling it off quickly and it takes some skin with it! I hate when that happens! ) Anyway the air hammer/chisel worked perfect for the outer sleeves for me, took me about 15 minutes
  7. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    One thing I noticed was if you use a sawzall you can cut the outer sleeve better if you lay the blade on the spring and use the gap where the spring eye wraps around that way you cut into it at an angle giving you more of an opening in the outer sleeve so its easier to ding it out with a hammer and chisel, I hope you can understand this if not, they WILL come out no matter what...
  8. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    sawzall to weaken it, and then a BIG screwdriver and a big hammer...
    /forums/images/icons/laugh.gif
    J
