Removing overspray from truck???
Discussion in 'The Garage' started by yeild2me, Oct 20, 2002.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    A couple of weeks ago, I repainted my rollcage, and now I have little black specks all over. What can I use to get this off???
    thanks
    rob
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    if you have a good clear coat, rubing compound...be careful as this stuff can be abrasive....check an inconspicuous area, then try other places....dont rub too hard it usually doesnt take much.
  3. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    Whatever you do...do not use goof-off as it will have adverse effects with the clear coat. Found that out the hard way /forums/images/graemlins/tongue.gif
  4. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    I had it painted with one-stage paint, so I dont have clear coat. I used some ether on a small part of the lower quarter panel and it took it off, but i really dont want to spend the whole day with ether!!
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Its a bit labor intensive but you can "clay" the surface. I know Discount Auto carries it down here. Its a Meguires product. It comes w/ a clay bar and a spray to lubricate the surface. Just spray the lube and rub it around. It will remove anything on the surface. It really shouldnt take TOO long. Maybe an hr or 2 to do the whole rig. OR get a NON grit compound and hand rub the truck. Either way you go do it in the shade.
    If you think your daily driver car has a nice smooth feel to it run over it w/ this clay and youll be amazed at how slick it will feel when you get all the contaminents off the surface. /forums/images/graemlins/thumb.gif
  6. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    I'll second the clay bar method.
  7. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    I may have been wrong, it might be a Mothers product. Not that it really matters there are several companies making the clay now.
    BTW COLLISION and I are both ex-bodymen. Hes in BS Management and Im a mechanic now. Trust us the clay is the way to go. /forums/images/graemlins/deal.gif
  8. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I'll also chime in on the clay bar. It DOES work. I used it for that exact purpose.
  9. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Use a clay bar and or some polishing compound Like 3M Finesse It II, Do not use rubbing compound as it is too agressive for single stage paint. I am a body and paint person and this is what I would do to my rig
