Removing Pinion and carrier bearings
Discussion in 'The Garage' started by Masher, Apr 8, 2003.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    I've got both my 60 and 14FF all stripped down. Now what is the best way to remove all the bearings?? Should I buy a bearing puller? If so anyone know any good inexpensive ones? I also have access to a press at work, would that be the way to go?
  2. Grim-Reaper
    7,385
    Atlanta
    A press with a bearing seperator will do it just fine. Just be very carefull of the shims under the bearings.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    press of the pinion bearing. Theres a special puller for the carrier. Dont think there are any shim behind the pinion bearing.??
