Removing Polyurathane Bushings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wayne, Sep 18, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I need to get the poly bushings out of my front springs to install the ORD ones I ordered. Alot of guys talk about burning out the rubber ones and I just want to know will it work as good on the poly ones and if not what is the best way to get them out?
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    If you have poly in your springs, then it's obviuosly aftermarket. You should be able to pry it out, since poly sticks out of the spring. The rubbers sits in the spring eye flush, so that's why it's easies to burn em out.
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  3. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The poly bushings are in my Superlift springs and I am swapping them out to the Greaseable ORD's. I ordered the shackel kit and the bushings for the front spring eyes.
  4. Boss
    2,550
    Maryland
    Oh, since they're on your springs and the springs aint even on the truck, just take a screw driver go in between the poly and spring and pry them out....should be monde easy. No need for torch. You may even be able to twist them out with your hand. I think I remember doing that to get mine out to put in greasable polys.
    Boss
  5. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    OK. Thanks Boss.
  6. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Chanel locks are the way to go. I did it to my ProComp sprinds. You can even do it to the factory frame rubber bushings. NO TORCH NEEDED. I'm in the process of replaceing my factory rear busings and may need to use some HEAT... Should only take 10 for 15 min. to do the whole thing GOOD LUCK....KEN
    DANGIT it's not a bronco!
