Removing raised steering arm
Discussion in 'The Garage' started by Yukon Jack, Jun 28, 2004.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I need to remove a raised steering arm off of a Dana 44 to put on a different Dana 44. After the three nuts are removed, is there a proper way to remove the arm or do I just use a 2 lbs sledge to work it off?
    Also, when I reinstall it, seems like I recall that you shouldn't reuse something, but I can't recall what the three parts are called.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just beat it with the biggest sledge you've got and it will come off eventually.
  3. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    the last one I removed I soaked it with P.B blaster for a few days then used a big hammer to beat on it. Also used a cheisel to work the tapered bushings loose.....Also before I started I used a wire wheel to clean up area........
  4. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Can I reuse the tapered bushings? Seems like I recall that you shouldn't, can't remember for sure though.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah you can reuse then, I did lots of times.
  6. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Thanks, a few smacks with my hand sized sledge and it came right off - actually came off faster than I thought it would.
