Removing Remote start?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Apr 20, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    When I purchased my truck, it had a Clifford Smart Remote Start III...It didn't work from day 1...Now that I am converting to manual, I won't ever need it, even if it worked. My question is this...What wires to remote starters tap into...? What is the best way to go about removing it? Basically, I no next to nothing about wiring and electrical issues and I want my truck to start when I finish with the conversion in a couple weeks...
    Chris
  2. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    I installed a audivox remote start on mine.. Do you have any small dip swithes mounted anywhere?
    You should have a small 4x6 box under the dash somewhere, Y ou can just start tracing the wires from there. If you can't find it, I know I wired to the light switch, Tach signal, brake switch, two wires to the battery, one to a hood switch, and one to a key on hot. Look them up on the web and they should have a schematic to help you.
    Hope this helps,,,
  3. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Ya, there is like a4"x6" box under teh steering column and there is a lighted rocker switch (ON-OFF-MOMENTARY ON) to the right of my light swith...I will see what I can get form clifford...
    Chris
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Why not try to make it work? If it's already in place use it. Just add a clutch interlock switch for your conversion.
  5. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Send me some email if you need any help. I can get the complete wiring diagram for your vehicle and the remote start.
