removing rivots
Discussion in 'The Garage' started by Bhintz, Feb 24, 2005.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Im starting my front spring swap tomorrow and need some ideas of how to get the rivots out especially in tight spot like the spring hanger brace were an angle grinder wont fit :confused:
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Your best bet is a good air hammer with a nice sharp bit. With these two it only takes about 30 seconds a rivet at the most, just as long as the bit stays sharp. Good luck!:D
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Plasma, or torch.
  4. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    get a long barrel air chisel and hammer down
  5. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    ok have no air tools or plasma or torch
  6. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    you can get to the back of them with and angle grinder, and pound them out. or if you are really good with a drill just drill them out
  7. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    ya you can get them with an angle grinder just go from the back side of the frame i just did it last week on mine then pund out the leftovers with a pointed chissel and a sledge worked good for me, i wouldnt try a torch i had a friend who did and ended up burning big ass holes in the frame.
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Sorry, not trying to hijack but when you guys use air chisels are you just going down from the top with a pointed bit and splitting the rivets or coming at them from the side with a flat bit and trying to shear the head off?
  9. BlueBlazer
    Feb 15, 2001
    1,940
    I shear the head, then change the bit to punch the rest through, works like a charm.
  10. s373n_rcr
    s373n_rcr Registered Member
    Jan 1, 2003
    63
    Ontario, Canada
    A die grinder with a good carbide bit should hack away at it pretty good.;)
  11. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    When I removed EVERY rivet from my frame I used a combination of 7" grinder, 4.5" grinder, air chisel, and drill bits. On most of the hard to get at rivets I took a good set of drill bits. I would start out with a very tiny bit and drill through the center of the rivet, I would then step up a few sizes, then a few more, etc., etc. until I cut down through the "head". A quick hit with the hammer/punch and it was removed. It was a little time consuming, but was the safest and cleanest of the methods.
    Good luck :thumb:
  12. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    yeah, us cool-tool-less guys have to use blood, sweat and tears. If you can reach the backside with a grinder, just grind it flush with the frame and use a punch + BFH to pound them out. Easiest way I can think of that doesn't involve a tool costing more than $50. ;)
    j
  13. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Call a buddy with a plasma, or torch.:)
  14. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    I wish Im the only guy that I know that has anything to do w/ this type of stuff
