Removing rubber impact strip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Jul 1, 2002.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    OK What is the best way to remove the black rubber impact strip on later K5's Peel off manualy and deal with removing residual glue? I want to remove these to for repainting with as little damage as possible to the metal. I dont care about the strips
  2. tRustyK5
    Jul 23, 2000
    36,184
    1,388
    E-town baby!
    Try a heat gun to soften up the glue...kinda like a hair dryer on steroids./forums/images/icons/smile.gif
    Rene
  3. Can Can
    15,553
    136
    Cochrane, Alberta, Canada
    Like Rene said, a heat gun works great to loosen up the strip. Start applying heat in a circular motion to one end and when it starts to lift, work your way down the body panel, pulling and heating as you go. Just make sure you wear a glove and don't keep the gun in one place for too long.
    To remove any leftover adhesive, soak a shop towel in some bug/tar remover and start wiping. Freshly uncovered adhesive comes off really easy.
    I just replaced a couple of pieces of trim on my 83 1/2 ton and the original stuff took a bit of effort to get off.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Hell I just grabbed a loose end and put my body weight into it! Didn't hurt the paint or body either. that stuff is really stuck on there hard, so hard that it pulled out a dent I had in the door ! /forums/images/icons/shocked.gif /forums/images/icons/smile.gif
