removing S-10 Blazer wiring harness
Discussion in 'The Garage' started by Jim Johnson, Jul 14, 2003.
  1. Jim Johnson
    Jim Johnson Registered Member
    Jan 26, 2003
    Middle, TN
    I had a 87'sh S-10 Blazer given to
    me minus the 4.3 engine. I am going
    to use the Blazer mainly for spare
    body parts. In exchange for the free
    blazer, the man wants me to remove
    and take back the wiring harness
    and computer that goes with the 4.3
    Is this going to be difficult and what
    do I need to look for. I am going to
    pick it up tonight.
  2. dyeager535
    Probably going to be a nightmare under the dash.
    If you don't need the interior stuff, it's probably 75% plastic, you can just break it out of the way. Real problem will be the fuse panel. I'm only guessing, but if he needs the fuse panel too (going to fit it to another vehicle or just replace a cut harness?) you are in for quite a bit of work. Most of the harnesses are all tied together, and although they unplug, there is no simple way to retrofit the "plugs" to another fuse panel, since the fuses are all different. (both amperage and what ignition position they work in)
    Look at the engine bay, if any wires are cut off, just tell the guy, and he probably won't want it anymore. /forums/images/graemlins/smile.gif
