removing shocks easy?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BranndonC, Nov 4, 2002.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok, my truck is so damn stiff and everyone is telling me that if i remove one shock from each tire it would be smoother. I have two on each now and i think they have been on there for years and years because they look so old, but how difficult would it be for me to remove one from every spot?
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    hummm...well, if they were valved for duals, then you shouldn't take one off. IIRC, the ones used for duals are valved for having another shock share in carrying the load.
    Single applications obviously would be the reverse of this. Which could be why your rig is so stiff. Can you get PN's off your current shocks?
    Also, remember to use PB Blaster. the stuff is worth its weight in platnium when dealing with rusty bolts
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    here ya go
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I took the front two off a couple of months ago cause the front end was so rough. Due to cashflow, I pulled an old set of coilovers (would like to try out the old race shocks), load levelers out of my father-in-law's garage and slapped them in. The ride is 100% better, mine you, I went from two on each side to one. Not exactly my gameplan, but it's a bandaid for now.
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    anyone recognize these shocks? can i remove one?
  6. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Go for it, I did it on mine. Removing one of the shocks in the front and disconecting the sway bar made my truck ride like my dad's cadillac, well almost as good. Just make sure you have a breaker bar and all that good stuff to get them off. Remember if you dont like the way it works with only 2 front shocks you can put them back on.
  7. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    im going to have to do my shocks soon to befor i can drive it..those things are just [censored]. i also have the quad setup in my front. i personly like the "look" of 4 shocks up front..but if i find it to ride bad..ill take them of..now this valving for 2 shocks thing i neverh eard of..i thought you just slap two shocks on it and that was it...
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    those are rancho PN, IIRC.
    Take on of them off. it will be loads better
  9. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I removed a shock on each side of my factory dual setup and it is better. I think I gained more ride quality by taking the sway bar off
  10. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Those don't appeat to be Rancho part numbers to me, but I would remove one from each wheel and see how you like it. Odds are it will be way better. </font color>
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks guys, i will try and take one off from each corner later today, but is there anything i should know before i screw up my truck? like special tools i need or which one to take off? thanks again you guys are the greatest here. CK5 Rocks! /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
  12. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Hey Brandon
    If those are gas shocks, definitely remove one.
    A lot of people make that mistake, I bought a blazer one that had 2 gas shocks per wheel in the front, it rode like hell, and it boke the mount off the axle. I removed them and put 2 quad shocks regular and it was good, then I removed them and put one heavy duty gas shock and it was much better.
    2 shocks would be good for the Dunes, if you want to go back to pismo /forums/images/graemlins/grin.gif
    2 shocks are good for high speed because you will have twice the amount of oil cooling.
    For slow trails one should be better.
