Removing spray bedliner
Discussion in 'The Garage' started by gjk5, Mar 3, 2005.
  1. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Just thought about this; I am painting the lower body on my K5 in black bedliner but it just occurred to me that it may be a little difficult to remove later should I want to repaint the whole truck. Anybody have any experience with this? Is that spray stuff gonna just want to stay there forever? the interior is already done in liner which is how i want to keep it, but not sure about the body.
  2. convertaburb
    convertaburb Registered Member
    Dec 22, 2004
    9
    las vegas nv
    spray liner material has to be chipped off with a hammer and chisel or maybe a putty knife. We do sprayliners where I work and if there is a mistake the stuff is pretty tuff to remove. But so are small dents, etc
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    someone once said that "black goes with anything". I wouldn't worry about it from a repainting point of view... I would worry about it with respect to what happens when you want to mod the body (trim fenders, skin some body panels, weld something to them etc etc etc).
    j
  4. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I hope this doesn't become an issue for me 'cause I'm getting my truck back Monday from Line-x. They are spraying the entire truck inside and out. No more rust problems though!
  5. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I had to remove some from the tub on my 72 to do some mods. I found the best way to get it off cleanly is to heat the metal from the back side with a good heat gun or propane torch and pull on the liner. This may only work if the liner is sprayed over paint or primer because it seemed like the paint was what was letting go. All the liner I pulled still had the paint stuck to the back side of it. Once I figured out how much heat it came off without too much trouble.
    Brent
  6. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    There was a problem with my friends truck when he got the spray in. I think they used some form of solvent to get it off. Spread it around wait an hour was the procedure. I think it was the chemical DBE.
    There is a solvent for every material you just have to figure out what it is.
  7. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Good point. Even if I have it painted later I will probably want to keep the lower body in the liner, just too many rock chips up here anyway. As far as trimming I hope not to trim at all on the sheet metal, I will probably keep at 35"s at the most and sounds like that's OK with 4" susp. and a little body lift.
  8. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Paint Stripper??
    Maybe that "Aircraft" paint stripper would take it off--there aint much that stuff wont dissolve in my experience!--one guy melted a big hole in a corvette he was stripping with that stuff!--If anything would remove it,I'd say that stuff would!..:crazy:
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Your going to like it. I had my k5 body done inside and out. It's sweet!
    If you need to remove it, it has to be chipped off. It depends on how well it's adhered to it's surface, which is a direct result of how well the thing was prepped first. Before they spray it, (were talking sheet metal and paint here, mine was gel-coat and fiberglass), it supposed to be scuffed up. They usally sand it with a fine grit sand paper. If you got good adhesion, it's not coming off.
