Removing Spring bushing
Discussion in 'The Garage' started by FL84K5, Sep 6, 2003.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    The shop that lifted my truck didn't grease the spring bushings in the front springs. What's the best way to remove the bushings so I can grease them? /forums/images/graemlins/confused.gif
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I took a long 3/8" threaded rod and found a tube that was just big enough for the bushing to slide into yet still fit on the leaf pack, then used a washer and nut on both sides of my 3/8? rod...tighten them up and the bushing slid out... /forums/images/graemlins/usaflag.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The key here is to drive out the steel bushing. I used the head of a 3/8" or 7/16" bolt...whichever one is the right size to just fit inside the rubber bushing hole without getting it wedged in there. So, pound out the steel sleeve, then you can usually grab onto one of the halves of the rubber bushing with a large channel lock pliers. Use a twisting motion and you'll most likely be able to get the one half out. For the other half, just pound it through from the other side. /forums/images/graemlins/thumb.gif
  4. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Thanks! Pnce I figured out the metal sleve needed to come out, things went a lot smoother. /forums/images/graemlins/thumb.gif
