Removing Spring Bushings
Discussion in 'The Garage' started by DwarF, Mar 22, 2003.
  1. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    I just got some f150 springs from a salvage yard, broke them aprat, cleaned them up some. But I am having a problem with the bushings. I can't get the bushings out of the leaf. I have tried a chisle and hammer and sledage hammer. I don't want to damage the spring, so let me know if I should just hit it harder, or if there is some ancient voodoo secret I missed. Since it is just rubber, I was thinking about heating it up with a torch?
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i wouldn't use a torch. i say drill it out.
  3. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    might be to late...but I've been told that the bushings in those are very good if they are white
  4. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Drill them out. Easiest way.
  5. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I torched them out. YOu can drill them but it was just easier to light them up and melt them out. If you have a press just use a piece of tubing that is closest to the outside diameter of the bushing. Really you will find the bushing is "part of" the spring now.
