Removing Spring Perches
Discussion in 'The Garage' started by petryshyn, Jun 18, 2005.
  1. petryshyn
    petryshyn 1/2 ton status
    Jun 6, 2004
    150
    Yorkton,Sk
    What is an easy way to remove these perches. Also how does the factory weld look on the axel, looking at mine I believe it is not stock. I was going to grind the welds off and then hopefully they would pop off. Also when I go to put the perches back on should i use the stock ones of fab up something myself.
    Another question, does anyone have a simple way to plug up the diff breath cover for storage and when i put new oil in so i don't get water in it?
  2. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    hey, you can get new spring perches at napa.
  3. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Grind the welds and then use a BFH to finish the job, works great. Also, I wouldn't completely seal the breather hole even for storage. Air pressure in the axle will push oil out the seals when it gets warm even from the weather or sitting in the sun. Cover it with something but make sure it isn't air-tight.
  4. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
  5. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    BIG F'N HAMMER.....It's a technical term :D
  6. bigcountryk5
    Mar 13, 2004
    931
    OOOOOOOOOOOH! they always get me on the technicalities! :blush:
  7. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i asked this question a week or to back.
    i followed a few members advise and used an angle grinder with a cut off wheel on it, grind/follow the weld on the sides and 2 ends, then wack it with a hammer, they will pop right off. took me about 5 mins and 2 cheapo cut off wheels
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I use a scarfing tip on my torch.You can cut realy close without getting into the tube.
    And making perches is easy enough and they are better than anything you can buy :D
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i wish i knew about those when i cut mine off, on the second one i cut, i didn;t have the torch level enough and i cut into the housing. it didn;t look like it went all the way threw, but when i turned it over, gear oil seaped out of it. i cleaned it up and welded it then ground it back down so you will never see my screw up :laugh:
  10. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    i have a question for you guys, if you cut into the tubing about the depth of the thickness of a quater is this a problem and did i destroy the rear end?
  11. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    no, just weld it up and grind it down
