Removing Spring Perches
Discussion in 'The Garage' started by Swanson52, Sep 16, 2002.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Is this just a matter of endless grinding until they submit?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    When I worked at a f*&d dealer, there was a service message to replace all the rivots on the front of f-150 and f250 trucks with bolts.(some stupid noise!!) we used to drill a hole through the center of the rivot 5/16 and then wack them off with a air chisel. took only a minute per rivot.
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    More or less...use a BFH and see if the remaining weld will crack. Careful not to gouge into the tube!!
    Rene
  4. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Yeah, that would make my frikkin monday! /forums/images/icons/smirk.gif
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I gouged mine a little...nothing a bit of weld and a few minutes grinding couldn't fix though. /forums/images/icons/shocked.gif /forums/images/icons/grin.gif
    Rene
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i took mine off with a acetaline torch then grined the leftover metal flat to the tube.the grinding took longer than the cutting. /forums/images/icons/laugh.gif
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I just did this last weekend. Pics... A sawzall will make it go faster, you can see the straight cuts that I made with a sawzall. After that there was a bit of material left so I worked on it with an angle grinder with a thin cutoff wheel and made small cuts from the top of the metal down to the tube, then worked from one side to the other to get it real close to the tube. After that I used a normal grinding disc to even it out. It took me about 4 hours to get it all done, I gouged the tube a little bit in 1 spot. </font color>
  8. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I did it without ruining the old perches.../forums/images/icons/tongue.gif
    Rene
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Aww geez Evan!! /forums/images/icons/tongue.gif No wonder you could use a sawz-all on those perches....those are the '85 and newer stamped-steel perches!! /forums/images/icons/tongue.gif
    If you had an '84 and older 14FF, those will have the cast perches, which will require the BFH and massive amounts of grinding to remove them.
    You got off easy with those perches, man! /forums/images/icons/tongue.gif /forums/images/icons/wink.gif
  10. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I got off easy!? Damn, I don't think I've seen the older ones, I thought these things were pretty beefy... I'll count myself as lucky, I guess! </font color>
  11. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Yeah, perches were on an 81 14B. BUT, with my 5" angle grinder, my BFH, and massive amounts of angry abuse, THEY HAVE BEEN LIBERATED!! HOORAY! What a f'ing PITA. /forums/images/icons/tongue.gif At least I did it at work, so theoretically, I got paid to do it. /forums/images/icons/grin.gif
