removing stickers from a window
Discussion in 'The Garage' started by adamforsythe, Mar 17, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    What should I do if I want to remove OLD stickers from my back window?
    Adam
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Warm soapy water and a razor blade.
    :D :D :D
  3. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    A good power washer up close should take it off, I took the dealership sticker off my blazer that way adhesive and all
  4. blazerpunk
    blazerpunk 1/2 ton status
    Feb 3, 2004
    121
    Trinidad, CO
    There's some stuff called oops. You should be able to find it at your hardware store. It works great for geting any of the glue residue off.:waytogo:
  5. dyeager535
    26,982
    191
    Straight razorblade (like for a box knife) will cut a sticker right off. The leftover adhesive will come off with paint thinner, lacquer thinner, etc. If you spend enough time with the razorblade, it will get the adhesive off too.
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    A product called "Goo Gone".
    You can smell that it's a petrolium base product,but it works excellant!
    That and a razor blade will work.
  7. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Acetone.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    peanut butter
  9. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Use a razor blade to get the sticker itself off. Then, instead of paying $5.00 for a can of Goof Off or Oops, but a $1.50 can of Zippo fluid. Same thing, WAY cheaper. I've done it a million times. Well, three times anyway.
  10. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    12 gauge worked for me. :eek1:
    :haha: :haha: :haha:
    Naw, really they sell a straight edge razor blade holder just for scraping things off glass. Bet Wally Mart has one for a buck!
  11. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    I always use Windex and a razor blade, prevents scratching of the glass and really eats away the glue adhesive. Works great and it's almost streak free
  12. swissk5
    swissk5 Registered Member
    Oct 18, 2004
    7
    Switzerland
    hot air gun, or a blow drier. don't make it too hot locally.
  13. 85jimmy3/4ton
    85jimmy3/4ton Registered Member
    Jan 7, 2005
    23
    Big Sky Country, Billings
    when i worked at a detail shop we used a razor blade and windex, -Just MAKE SURE to use plenty of lube (windex or something like that) and a new razor blade to prevent scratching the glass, this method can also be used to remove pinstriping or those dealership decals just take your time. Chris
