Removing stickers from painted metal?
Discussion in 'The Garage' started by dontoe, Mar 13, 2005.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I'm in the process of painting the Jimmy and need to remove some stickers from the fenders. Any ideas? Other than shotgun blast!
  2. Mantruck-k5
    Mantruck-k5 Registered Member
    Feb 16, 2005
    18
    Fairfield CA
    Heat
    Use a hair dryer or an actual heat gun to soften the adhesive. Old stickers should pull right off. If you use a heat gun be careful. You can bubble the existing paint in no time. Might not be an issue if you're repainting... This is how body shops remove old pinstriping and such.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there is a bottle of stuff called "sticker off". you spray it on and wait a bit while it desolves the glue. then just pull it off.
    i know bikeshops can get it, i would imagine that a auto parts store can get it also.
    ive also had good luck with the hair drier trick.
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I have a "heat gun" for heatshrinking stuff. I'll try that first and head to Lowes or Auto parts for the glue removing stuff if there is any problems.
    Thanks................well it will have to wait....clouding up really fast.........looks like rain soon. I'll get a photo of the progress and post it in da lounge. Better get my chit put up.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    "Goo Gone" works extremely well at removing old sticker adhesive. You can buy it at the grocery store in the cleaning products aisle; it's an orange liquid in a clear bottle.
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I'll try it. I almost finished the hood, but the rain came and shut me down. 3/4's of it looks good. I posted it under a different post.
  7. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I 2nd the GOO GONE. That stuff works wonders!!:)
  8. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    use a hair dryer
    always had good luck with that
  9. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    when i worked in a body shop we used an eraser wheel, you can get them at a paint supply store, hooks up to a drill or air grinder..and takes the pinstipping or sticker right off and doesn't mess up the paint..just hand buff it when you are done and you'll never know it was there
  10. Grim-Reaper
    7,385
    Atlanta
    Ok where are the pictures? Got to see what it looks like now.
  11. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    I 2nd that!
  12. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Yep. Goo Gone is great. Nobody with kids should be without it and it works wonders on stickers.
  13. jekquistk5
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    Goo-gone gel is alot better then the original. It doesn't run all over the place. IMHO
  14. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I second the rubber wheel. 3M makes a good one -- takes it right off no chemicals involved.
