Removing stripped rear end fill plug
Discussion in 'The Garage' started by bwalkerc2, Nov 9, 2005.
  1. bwalkerc2
    bwalkerc2 Newbie
    Nov 1, 2005
    3
    Georgia
    Can someone give me advice on how to remove the stripped fill plug on my 1998 k1500 chevy. Found it stripped after I bought the truck. Has the square insert head that has been rounded out. Any advice would be helpful
  2. bobalob
    bobalob 1/2 ton status
    Jul 20, 2005
    157
    Everson, Washington
    grind the edges down a bit till flat enough to get a wrench on
  3. crimescene
    crimescene Registered Member
    Oct 27, 2005
    79
    KS. OR MO.
    That is gonna be fun! I had one in the same shape, I got an easy out from NAPA, the square tapered one and used the one that was just short of falling in the plug, tapped it in with a hammer, (into the stripped part of the plug) then I got a handheld torch and heated the area around the plug trying to avoid heating the plug directly, and with a little time it came out, no damage to the housing or threads in the housing. GOOD LUCK!
  4. bobalob
    Jul 20, 2005
    157
    Everson, Washington
    just read again oops
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Weld a short bolt into the hole, then use a wrench to remove it. easy.
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Dido, welded a nut to mine.
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    what he said
  8. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    i take a bolt also and hammer it in the hole and weld asmuch as possible and it comes out no problem.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    When you get it out , get a plug with external flats for a wrench . I have had an axle with both , and I like the one for a wrench better :D
