removing t.p.i......have a question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tmanofcali, Jan 6, 2002.
  1. tmanofcali
    tmanofcali 1/2 ton status
    Mar 20, 2001
    372
    lodi, ca
    ok.....im pulling the t.p.i. setup off of a 86 z-28. i need to know in what order does the setup come off? do you unbolt the top/tubes first and then the fuel runners? or does it matter? i know just about nothing about this setup so any info is helpful. is there any secret ways of getting it all off in one peice? can you remove the top and the runners together? please give me info a.s.a.p. .........well....back to pulling the wiring....thanks...tmanofcali
    <a target="_blank" href=http://community.webshots.com/user/tmanofcali1>http://community.webshots.com/user/tmanofcali1</a>
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Hey todd you should be able to just take off the fuel lines and the radiator hose and the take the Marked wires to the sensors and then unbolt the intake and take it off un plug the ecm and take it out from the eng side (wire harness)
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Remove the throttle body from the plenum (10 mm socket), then remove the top runner-to-plenum bolts (4 per side if I remember right, use a Torx 40 or 45), remove plenum. Then remove the lower runner-to-intake bolts (think they are T-40 or 45), then you can pull the manifold off. That should do it............and you shouldn't have to remove the fuel rail at all until you want to pull things apart.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  4. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    good thing i showed up there tonight to help...they dident have any torx sockets! hehe [​IMG]
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  5. tmanofcali
    Mar 20, 2001
    372
    lodi, ca
    yeah chaz .......thanks again later
