Removing Tapererd Sleeves in Steering Arm
Discussion in 'The Garage' started by tycos, Aug 10, 2004.
  1. tycos
    tycos Newbie
    Aug 10, 2004
    I'm am having no luck in removing the tapered sleeves that drop into the steering arm so I can install the larger one that came with my lift kit. Is there a tool or trick to getting these out??? /forums/images/graemlins/k5.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    torch. THose things are a huge pain, and I've never personally seen a steering arm removed without torching it off, studs and all.
  3. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    BFH and heat... Try heating the studs then put the vicegrips
    to work..
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    heating the steering arm makes more sense to me. I've never personally done it, but if you heat the studs, they will expand and only make things worse. When you are trying to get a bolt out of something, you heat the thing it is in or the nut, not the bolt, at least in my experience.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    BFH and lots of hitting. Try hitting different places on the arm. Once you get the cone washers to unseat some you might be able to open up the gap with a screwdriver and pull them off. Or try and get ahold of them with a set of channel locks.
    BFH and lots of determination is the best answer.
    I have taken a couple of steering arms off axles without the use of heat. Just a BFH and some heavy hitting. I live in AZ though so rust is something I don't know a heck of a lot about.
    Harley
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Best luck I had was taking a 3+ pound sledge and hitting the arm right on the numbers stamed on the arm towards the draglink. This seems to be a sweet spot and will pop the cones up. I had 2 pop out and one come up hgh enough that I could then unscrew it off the stud. Try hitting it right on those numbers with a couple hard hits and see what happend. /forums/images/graemlins/thumb.gif
  7. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Soak the cone's in pb blaster for a couple hours or more. Tap a screw driver into the slots to open the cones up a little and pour more pb blaster inside. Let it sit for a few more hours and start hitting it with a hammer on the numbers, as said, hit up a few times, and down a fiew times, do not hit in one direction only! If this doesn't work heat everything up since the heat will break up any rist and the expanding and shrinking of the various parts will break any bond (hopefully) allowing you to use the BFH to losten up the cones. It's not a fun job, but after doing about 5 of these with great success it's ;ess frustrating for me. Good luck /forums/images/graemlins/grin.gif
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Isnt he just trying to remove the tapered sleeves and not the steering arm??
    /forums/images/graemlins/dunno.gifThat said I would just soak it in some penetrating oil and then try and TAP them out with a hammer. /forums/images/graemlins/thumb.gif
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    He is installing a raised steering arm that you use with lift kits to correct the draglink angle after the lift. Or at least that is what I gather from his post.
    Harley
  10. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea I know I just thought he ment he had the steering arm off and the tapered sleeves were stuck in the arm and he needs them to use on his raised steering arm correct??
  11. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
  12. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    You have to hit the arm itself, this will break the cones loose. I never have used heat as it could screw up your ball joint boot. I have taken many of them off and have found a system that never requires more than about 5 or 6 hits, but I will never reveal my secret... nobody ever listens anyway.
  13. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Ive taken about 4 off in the past year and all ive needed was a 3lb hammer, flat screwdriver and a punch. I usually take several hits with the BFH then take the punch and hit directly down on the cone washer once maybe twice. Use the screwdriver to wedge in the opening of the washer to spin it around the stud like your unscrewing it. It will test your patients but Ive never spent more than 20 minutes from start to finish. I need to make a video the next time i do it! Rust hasnt got anything to do with it. Ive got plenty of that to show! /forums/images/graemlins/shame.gif
  14. cdh
    cdh Registered Member
    May 6, 2002
    69
    Gilbert, Arizona
    I removed mine last night with a BFH and a couple of hits right on the numbers as described above, worked great.
  15. dlaw36
    dlaw36 Registered Member
    Jan 11, 2003
    71
    I used a BFH with a torch. Pounded and heated for 30 minutes and finally came off. Burnt up my upper ball joint though. I needed to replace that anyway!
