Removing the 205 in the driveway
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 72_jimmy, Dec 2, 2005.
  1. 72_jimmy
    72_jimmy Registered Member
    Jul 30, 2005
    54
    East Texas
    What is the best way to get the np 205 out in the driveway without killing myself? I need to pull the engine/tranny too. What is the best order of operations? I know for a fact that I can't pick the case up off the ground by myself, so I am a little scared of dropping it on my head.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've done it with a 203 in the drive way with a proper trans trolley. It was hard work. Last week I was pulling the motor too. It is WAY easier to pull the motor then take the trans and t/case out together but you really need a trans jack or a lot of help. They're HEAVY!
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you could build a small cradle under it, then remove it and set it on the cradle, then remove some of the items holding the cradle and slide it all out at once....
    otherwise a couple friends and or a transmission or ATV jack work well.
    transmission is next, same thing. then engine. support the engine once the tranny is out.
    grant
  4. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    does your exhaust cross under the tranny? if not I say drop the tranny/tc case/cross member together, that's what I did with my TH400/241 combo, needed two floor jacks.
    Support the back of the motor though then pull the motor.
  5. 72_jimmy
    Jul 30, 2005
    54
    East Texas
    Would pulling the engine and tranny together be a good idea? Is it possible? Then the T-case would be left to be dealt with on its own.
  6. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I vote for the motorcycle/atv jack. I bought one and have used it several times to remove t-cases and trannys. Cheapest and safest combo in my opinion.
  7. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Eat your wheaties..... :haha:
    Seriously, I had mine out and back in last week. Tranny jack is the way to go. Even then you'll need to be careful as the center of gravity of the 205 will want to make it slide off.
    By the way, I don't know what your setup is, but I can't pull my tranny without removing the t-case first. There are 4 bolts through the adapter that I can only get to once the case is out.
  8. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    I do one of two things and they both work. Make a plate to fit a floorjack that you can trap it to. The ther works better if you have a helper, but it is faster than the floorjack way. Get a 2" ratchet strap with a flat hook on one end, I use a mi-spec one. Hook the ratchet to the fram somewhere, wrap the strap around the case, then take the hook and slip it between the body and the top of the framerail, make a loop to put your foot into. Now your helper can balance it while you lower it.
  9. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    I took a 12''x16''x2'' board and drilled a whole in it and bolted the rite size deap well socket to fit my floorjack to it. It fit under the tranny and t-case
    wow thats really redneck isint it lol :haha:
  10. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I used a cherry picker.Removed the tranny tunnel and went in through passenger door,worked real slick...:D
  11. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Go see Tonyraca
  12. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    Let me know where you live, and i'll come move it into the back of my truck, and into another one of my trucks :)
  13. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i benched mine, not so bad. the worst is putting it back in. might need some help :eek1:
    or tranny jack prolly
  14. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I dropped the tranny/tcase combo (th350/np203, full of fluids, whoops) by myself, I just popped open the trans tunnel (no carpet at the time), stuck an engine hoist through the door and chained to the tranny. Put it back in the same way.
  15. the beast
    Oct 15, 2003
    535
    Providence, RI
    That's slick. I'll have to remember that for next time.
  16. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Back into your grass yard and kick that 205 onto the ground. You wont hurt it:D
  17. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Just bought a tranny jack adapter and a new floor jack at HF. My 208 was super easy.
    Jesse
  18. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    Engine Hoist
    Im also a user of the Engine Hoist through the tranny tunnel method. I pulled the seats, removed the tunnel cover, and dropped it out the bottom onto a wagon, tranny and the 205. Then i got a lil crazy and cut the floor so i can now take it out through the top. :D
  19. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I cheated and uesd a forklift. no roof and a long chain through the tunnel worked really slick! mine was a 203/305 doubler
