Removing the Cat
Discussion in 'The Garage' started by dammit32, Jun 15, 2003.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    if i put a straight pipe in place of my cat will my O2 sensor freak out? Is there a work around for this or should i just leave well enough alone?
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i dont know about maines laws but if you removed your cat here in PA you would not pass inspection.unless you "know somebody" that can get you a sticker.
  3. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    On a 91 truck I believe there is only one o2 sensor just upstream of the cat. If this is the case exaust modifications downstream from the o2 sensor should have little to no effect on it.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I took mine out, wwith no problems and all gain....
  5. dyeager535
    26,982
    191
    If you arne't having problems, leave it be.
    You know the old adage, "if it ain't broke, don't fix it". Well, for automotive I think that should be changed to "if it ain't broke, don't change it, because you'll find something else that's screwed up in the process" /forums/images/graemlins/smile.gif
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    if it aint broke, fix it til it is..
  7. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    You know its a federal offense to remove cats right? on that note, My 84 doesnt have cats anymore, either.
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I would leave it alone or you could replace it with a Catco for about 50 clams
