Removing the doors on an 84???
Discussion in 'The Garage' started by Hektyk, Apr 27, 2003.
  1. Hektyk
    Hektyk Registered Member
    Feb 4, 2003
    51
    DFW TEXAS
    I was wondering how this is done? I have all the wires that run through the door jam. I s there a way to disconnect them so I can remove the door and if so are the running to anything inportant or are they running to the power windows and power locks? /forums/images/graemlins/smile.gif
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Yes, they just run to the locks and windows. I have never messed with power doors so I dont know if there is an easy way to disconnect them. If not, you could probably install some kind of plug(s).
  3. Hektyk
    Feb 4, 2003
    51
    DFW TEXAS
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I did just this on my '82 last month. I also have the power windows and door. There are, I think 9 or so wires on each side. I got some do it yourself wire plugs and cut the wires and put them into a plug. So now, I pull the plug and the pins and off the doors come. Worked out nice.
  5. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i just cut the wires and used connectors. makes things easy for quickly removing and attaching the doors.
    /forums/images/graemlins/thumb.gif
  6. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Make sure you disconnect your battery! The window and door wires make good welders!
  7. Hektyk
    Feb 4, 2003
    51
    DFW TEXAS
    Thanks guys yall ROCK. /forums/images/graemlins/thumb.gif
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    They are plugs inside the door for the lock and the window motor, but I do not think that they will fit through the rubber tube in the door jamb...
