Removing the E-brake pedal assembly
Discussion in 'The Garage' started by UseYourBlinker, Dec 26, 2006.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    How to remove? Any tips or tricks that I might need to know? :confused: Went to rear disk's on my 14 bolt,so I don't need the pedal/and assembly. It's on a 84k5.
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    2 nuts on the firewall (take nuts off from the engine compartment) and 1 bolt on the hinge pillar on the inside.
    Disconnect the cable on both ends, IIRC, you have to pull the entire cable back through from the inside. Disconnects from the pedal very easy, the other end of it is underneath on the driversside attached to the equalizer, with slack, it should come right out.
    Pretty stragithforward.
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    Get your ass back in the lounge :haha::haha:
    I have no cable so I guess..I could finger it out tomorrow then. :bow: Thanks mang.
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I would leave it there and someday go to eldo calipers and make the e-brake work. If you're ever going to winch the tranny needs to be in nuetral with the e-brake on or you'll break a tranny.
  5. UseYourBlinker
    Jun 7, 2000
    11,117
    What about just using my foot on the brake pedal? :confused:
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Well, that would work assuming you don't need to be outside the truck for anything.
  7. UseYourBlinker
    Jun 7, 2000
    11,117
    Yep.. Plus I don't want to get rained on.:haha:
  8. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Pulling the pedal assembly was pretty easy. Certainly if I did it:o:o
    Like the others I'd suggest keeping it. You can use a long ty-wrap to keep it up & out of the way.
