Removing the spindle bearing on a D60?
Discussion in 'The Garage' started by fortcollinsram, Nov 19, 2003.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    How in the heck do you do it? I have tried everything short of cutting the spindle in half to get the damn spindle bearing out...Let me know what you det to get that damn thing out...
    Chris
  2. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    I've seen a lot of people take a long flat screw driver and heat/bend the last couple of inches to about 45*. This will allow you to go in from the outer end and behind the bearing with the flat tip to drive it out.
    There is a specific tool to do this but I can't find it on the net at either Snap On or Lisle Tools (I think Lisle actually makes it). The tool looks like a bar stool, the legs will compress together to slide down the throat of the spindle and expand behind the bearng just like the screw driver idea. Once in place you hit the "seat" with a hammer to drive out the bearing.
    I have the tool, bought mine from Snap On (made me a deal 'cause he didn't know what it was) but I've seen them in parts houses in the Lisle Tool section.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Autozone has a tool like that that goes on a slide hammer to remove pilot bushings/bearings. You might try that. They rent it for free!
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    i second the slide hammer
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    we made something similar to the previous idea of a bent screwdriver. but we used a piece of rod with a washer welded to the end.
  6. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Long brass punch. Reach through at an angle, work opposite sides using a 3lb sledge. Approx. 2 min per side. The slide hammer is OK, but you have to have some way of holding the spindle to use it. That can be a difficult thing.
  7. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    That's how I did mine.
  8. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I heated mine up and tapped the spindal a few times and it came right out.
  9. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    The first ones I did, I used a air powered die grinder with a cone shaped abrasive stone to grind almost all the way through in one spot, the knocked them out. Now I have an old tire tool my friend found that fit very well and has a bend similar to the heated up screwdriver method. It will knock them right out.
  10. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Here is a pic of my tool. It is Blue Point #YA2250 but I believe Lisle Tools actually makes it.
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't know if this will work on a D60, but when I did the spindle bearings in my Jeeps D35 I installed the spindles backward on there studs on the Knuckle. (no axleshafts installed). I put the nuts on the bolts to hold the spindle in place and then I used a slide hammer to put them out. Worked like a dream.
    Harley
