removing top?
Discussion in 'The Garage' started by stizkidz, Jun 13, 2005.
  1. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    I can;t seem to find the last 2 bolts holding the top onto the body on my 1990 K5. How do I get this thing off? The bolts that I cannot find are the last 2 on either side towards the tailgate. I'm sure I am missing something obvious - but what is it!!!???
  2. tdcombs
    tdcombs Registered Member
    Apr 12, 2005
    98
    missouri
    Take the side panels off and they last tow bolts at the back should be easy to see.
  3. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    duu read your other post . i replyed in there.:screwy: :grin:
  4. rusty79beast
    rusty79beast Registered Member
    Sep 30, 2002
    64
    Houghton, MI
    You have to peel back the interior panel back there to reveal the last two bolts!
  5. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    the last two bolts are directly in the corners of the rear where the fat part of the top is.. like others said peel back ur side panel on the inside.
  6. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    since 3 previous people put almost the exact same post... i will play too
    just pull the side off and the bolts are there :D
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    same as everyone else.
    also if the top has never been taken off the seals will prolly be stuck, so jus lift off. u wont be able to slide it after u ahve all teh bolts off cuz there are 2 safety cones that u ahve to lift it off of b4 u can slide. once u have the top off u can use a screw driver and a socket to get those off, it makes life easier.
  8. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    keep those cones on!!!
    it makes life so much easyer when putting the top back on!
  9. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    agreed - lining it back up will be a breeze...
    just a little tip... the trim inside the hardtop on the sides can be bolted back on when the shell is off. my 79 had white scuffs from the top rubbing over the years and it looked cleaner with the trim on it.
