Removing torque converter bolts...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by danzoso, May 24, 2003.
  1. danzoso
    danzoso Newbie
    May 20, 2003
    3
    florida
    When removing the torque converter bolts, will putting the trans in neutral make it possible to turn the converter and flywheel, so I can access the other two converter bolts?
    almost ready to drop the tranny...... /forums/images/graemlins/k5.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    yep /forums/images/graemlins/thumb.gif
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    tranny gear should make no difference in wether the torque converter turns or not. It will turn no matter what gear the tranny is in. The problem is when you turn the converter and flexplate you are turning over the engine. It can be done by wedging a wrench in there and turning it.
    If it was a manual tranny it would make a difference, but manuals do not have torque converters.
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    You can also go the cheap route, and turn the flex plate with a screw driver used on the teeth of the flex plate, on the starter side. Thats how I've always done it... I'm just too cheap to buy the real tool for the job! /forums/images/graemlins/laugh.gif Throw some muscle at it, and watch out for your knuckles if you slip off! /forums/images/graemlins/wink.gif
    -Dan
  5. khotmer
    khotmer 1/2 ton status
    Oct 23, 2002
    228
    columbus, oh
    harbor freight has the tool for 4.95. I picked one up for my swap last month .....Wouldnt do the job without it for 5.00...
