removing tubes from housing...how?
Discussion in 'Center Of Gravity' started by dustinellis, Feb 29, 2004.
  1. dustinellis
    dustinellis Registered Member
    Oct 30, 2003
    31
    south texas
    i am trying to build a 14b front axle but i cant get the rosette welds drilled,burned or whatever,how has anyone done it,i plan on using crane kingpin inners and outers should be tuff enough.
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I just use a torch and burn through the welds and through the tube. It's about 1" of material, just work around the edges pointing in and cut little by little and it will pop through the wall of the tube in the center and then just work your way out till the weld is gone and your to the cast housing.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah right on me too!! Im having a shop do it.
