Removing welded receiver hitch, torch or cut?
Discussion in 'The Garage' started by 14-Bolt, May 11, 2012.
  1. 14-Bolt
    14-Bolt 1/2 ton status
    Oct 24, 2009
    229
    Oregon
    I can either torch it off or cut it off with air tools or cut off wheel on grinder. Torch is fastest but with the gas tank a few inches behind I am very hesitant. What would you guys do?
  2. Fordum
    Fordum 3/4 ton status Premium Member
    Jul 31, 2008
    9,751
    41
    Fl
    It doesn't look like there is a real good answer. I'm like you, I don't like the torch. Grinder or cutoff wheel is only a little better. Still lots of sparks, just not as much heat and open flame.
    Air chisel would be the safest I suppose, but probably really slow.
    Looks like that one weld is ready to let go anyway. You could always use a hacksaw and lots of blades..........
    Sawsall would do good, but not sure if you could get one in there.
  3. Jester1
    Jester1 1/2 ton status
    May 8, 2011
    1,224
    8
    Belgrade, MT
    Plasma and hot blanket?
    Sawzall and grinder to clean up?
    Sell it a buy another thats not welded.:haha:
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    why not drop the tank the use whatever you want?
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,161
    Sacramento, CA
    Obviously you don't have one since you didn't list it as an option but I like Plazma cutting in this situation.
    Fast and clean and the risk of blowing up is pretty slim if you do it right.
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,866
    37
    Drop the tank. No worries, no danger, less than an hour of work.
  7. dremu
    Feb 27, 2000
    15,768
    177
    East of San Francisco
    Amen. Coupla chunks of 4x4 scrap lumber, and the appropriate jack, it's easy enough.
    Unless the welded-on hitch is blocking the removal of the skidplate or something?
    -- A
  8. 63chevyll
    63chevyll 1/2 ton status
    Aug 13, 2009
    4,513
    Colorado Springs
    yeah...what he said.
    i went through same thing and used torch, then hammer, than grinder, then flap wheel
  9. 14-Bolt
    Oct 24, 2009
    229
    Oregon
    No plazma, if it drove i'd take it to my work and use theres but drivetrain is out. Never thought of dropping gas tank. I'm putting in ORD 1" body lift and new poly mounts, so dropping tank, would make that job easier to boot. Then I can torch of hitch in no time. Anything I need to look out for? I just detach all the lines at the top of tank.
  10. 14-Bolt
    Oct 24, 2009
    229
    Oregon
    I thought about keeping hitch, but I didn't by this truck to tow ****. I bought it to have fun and build it for hardcore offroad. And tow it.;)
  11. ion
    ion 1/2 ton status
    Jun 8, 2011
    1,834
    Dayton, NV
    A hitch can always come in handy in situations. They make decent recovery points, and A half way good spot to start a custom bumper off of.
  12. 14-Bolt
    Oct 24, 2009
    229
    Oregon
    This hitch was a piece of crap and so were the po's welds, no way safe. Got it off this weekend, dropped the tank, bumper now on to the suprises, just lifted ok looking carpet to find a mess of ****. One more thing to fix, all these things just so I can puy my damn doubler in.
  13. 14-Bolt
    Oct 24, 2009
    229
    Oregon
    Is the frame supposed to look all wavy? or is that way because of the weight of whatever was towed?
  14. imiceman44
    Aug 5, 2002
    15,161
    Sacramento, CA
    The bump you see with a big hole in the middle is stock, no idea yet why they did that but it is on the K5.
    That is why a regular hitch doesn't fit on a K5 from a truck
