repacking bearings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crashfirepm53, Aug 25, 2004.
  1. crashfirepm53
    crashfirepm53 Registered Member
    Mar 14, 2004
    62
    florida
    Any special I should know on repacking the bearings on the front 10 bolt w/ locking hubs or is it straightforward?
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    nope just fill them with grease like you would any other bearing.
  3. jon v
    jon v Registered Member
    Jul 8, 2004
    22
    Hesperia, CA, USA
    Have you ever checked the spindle bearings? Every spring a good time to clean and repack them. /forums/images/graemlins/cool.gif
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    A pretty simple and sorta clean way to pack bearings is to take a handful of grease and put it in a ziplock baggie. Then drop the bearing in and squeeze the air out then start squishing the grease in the bearing. Works well and doesnt make too big a mess /forums/images/graemlins/thumb.gif
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Cool tip /forums/images/graemlins/thumb.gif
  6. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Here's a variation on the ziploc. Little quicker but don't let your wife catch ya.
    clickety here
  7. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Not to hijack but since that draws the air out does it actually draw the grease into the bearing like it should or do you still have to push it in the bearing. Just trying to justify actually buying one since I'll be able to use it as much as the wife will.
  8. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I've done it two or three times now and it makes a difference where in the bag you put the grease. Some in the corners, some in the center and then some more in on top of the bearings. Basically distributing it around the bearing so it pulls in better. When the air is drawn out, the resulting vaccum pulls the grease into the voids. You can kinda help it along too as its sucking the air out. I like it. My DD all the wheel bearings were done this way and no trauma thus far and I got quite a few miles on it already since the axle swap.
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Thats awesome...I like this...I was just packing bearings yesterday for my old Impala..what a mess I hate it, but this is great....
