Repair panel basics, tips, tricks...
Discussion in 'The Body Shop' started by heavy4x4, May 4, 2004.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Post up everything you know about replacing body panels (repairing rust holes, fender openings, rockers, etc). Anything from tips like "hold a brass sheet behind the two panels being welded, the welding wire won't stick to it"...to tips and tricks for making good-matching patches...to welder settings/speed...to step-by-step instructions....to _________
    This post will be a good resource in this forum (and help me /forums/images/graemlins/grin.gif)
  2. namkrow
    namkrow 1/2 ton status
    Apr 25, 2004
    166
    So Cal
    There is a special tool available for drilling out spot welds. Even though you use the tool, you'll still have to pry the pieces apart.
    Still learning....
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Cut out more than you think /forums/images/graemlins/histerical.gif rust under the surface is 10x's as bad as you think.
    Weld seams at body lines.
    Flange your sheet metal when making panels.
    When butt welding two pieces of steel over 1/8" grind a 45 at the end of the two pieces /forums/images/graemlins/grind.gif then weld in the V
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    couple off the top of my head.
    weldthru primer.... spray it on all grinded areas to be welded.
    heat dam. wet towel placed in circle around welding area to keep warpage contained. they use to make a modeling clay stuff for this that was reusable. haven't seen it in years, prolly took it off the market for being loaded with asbestos. /forums/images/graemlins/eek.gif
    for factory style spotwelds... drill or tool punch holes in weld areas prior to assembly. fill with mig.... spotweld bits are invaluable for disassembly... that and a air hammer...
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Get a catalog from Eastwood. All kinds of gadgets in there for sheet metal work, bodywork, etc. If you don't want to buy the stuff, look at the pictures and make your own!!
  6. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    Pick up a Cleco (sp?) set. It's like a removable spring-loaded pop-rivet that's handy for holding panels in place for fitment & welding. I think my set came from Summit, but imagine Eastwood & others carry them.
  7. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    whats the proper way to plug weld, when the top piece (piece with the hole) is thinner than the lower piece (solid piece that the sheet sits on) i believe it's called a plug weld, maybe a spot weld?
    example; top piece is 18-20 guage sheet with i'd say 3/8" holes drilled in it, and the lower piece is 1/8" 2x4
    thanks again, nate /forums/images/graemlins/k5.gif
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I'm doing plug welds on my bumpers, inserting tube inside of tube and welding them together.
    I think the right way to do plug welds for any thickness is to start at the center of the hole and go aroundwith a bead till you melt into the top section. Then if it where me, I would lay a weld 1' square over the top of that then use a flap wheel on a grinder to taper the weld out. You dont want to grind it flat in the case of thin sheet on top, it could still seperate.
  9. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    ok this is what i would do...step 1. get the yellow pages step 2. call a body shop step 3. pay them to do it since i hate messing around with rust and bodys....haha just my 2 cents
  10. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Hmm, after thinking about it I will tell you more about how I replaced all my rusted out sheetmetal, I can garantee it is the easiest and most effective meathod I have found to date...
    Pack up everything you own and move out west. Part out rusty 'Burb and S10 Blazer then buy cheap rust free/straight old ranch truck from original owners grandson /forums/images/graemlins/whistling.gif
  11. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/angryfire.gif
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/frown.gif
  12. devilsquid
    devilsquid Registered Member
    Apr 22, 2004
    91
    Groton, CT
    Make sure you cut the bad out before putting new stuff in.
    Use sheet metal in place of fiberglass and fillers whenever possible.
  13. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    and if its an area where you cant weld up,(like small pit holes)use a fiberglass reinforced filler(Dynaglass, Tiger Hair, Duraglass, etc), because regular bondo isnt waterproof.
    so you might be able to paint it from the outside, but from the inside its just exposed bondo, which is porous, soaks up water and bullseye.
