Repair the end of the axle housing?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77fixer, May 10, 2003.
  1. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I was given a 79 D44-8F that has damage to one of the holes where the ball joints bolt in. How practical would it be to have it welded and a bored out. I assume it's a tapered hole. I understand I can swap the parts (gears, axles, spindles) into the 44-5CF in my K5, but the older 44 uses 2 3/4" tubes vs. 3" on the newer axle. Is one housing stronger than the other?
    Should I try to repair the axle or just swap the parts?
    Brett
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    We're not having much luck here....
