Repairing a rusty frame?
Discussion in 'The Garage' started by JeremyK5, Apr 10, 2006.
  1. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    My '78 c30 cab & chassis truck had a flatbed on it that used wooden spacers between it and the frame. When I pulled the flatbed off to put on a regular bed, I found some pretty bad rust. The rust is on the top of the framerail, in every spot that wood was sitting on it. The problem varies from being thinner than it should be, to seeing daylight through it.
    Would it be better to weld on steel to plate over the rusted areas, or cut them out and weld in replacement pieces?
    Here are some pictures-
  2. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    im not realy sure but i would box in the rear to add strenght becuase it looks like its pretty weak back there from the rust
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you could try and splice in that part of the frame from another truck, i had a small area of frame rot on my k-5 that i made steel plates for and welded them in
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I personally would start looking for another frame/truck
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Check
  6. sweetk30
    Nov 1, 2004
    25,545
    540
    horseheads , ny 14845
    x2 in my eyes
  7. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    bad memories!...
    That reminds me of my 74 K20's frame..I ended up scrapping it, and stripping the good parts off, and selling the leftovers...its a common death here for cars and trucks,to just erode and crumble away until nothing is left..
    There should be a layer of tarpaper or roof shingles under every wooden bed spacer for this reason..rubber traps moisture too,like when cab mount bushings keep the cab mounts wet constantly,and rust develops quickly..
    I'd say look for a better frame if possible...you could patch yours up using donor peices from a 2wd frame,but by the looks of the inner rails,it looks like you'll be chasing rust forever..my trucks rails were thin enough to poke a screwdriver thru them easily in spots,and the entire frame had spots that were peeling apart in layers like de-laminated plywood..:( ..So I decided putting another tranny in it after it lost reverse was a waste of effort,and lit my torch..:frown1: ..I'd hate to be hauling a heavy load of junk and have it give way on the road!..:eek1:
    If it were a rare antique,you'd have to fix what you've got..but there are so many trucks in junkyards now that still have decent frames ,but poor sheet metal,its hardly worth the time and effort to fix it..:crazy:
  8. JeremyK5
    Aug 12, 2001
    549
    Indiana
    I'll probably try welding in some new steel, it'll be a lot easier than finding a frame.
  9. JeremyK5
    Aug 12, 2001
    549
    Indiana
    The problem with that is that there are very few c30's in any of the junkyards within easy driving distance of where I live. The few I've seen in the junkyards are worse than mine.
    And buying another truck isn't an option, because every 1-ton I've seen in the paper, or along the road has been $2,000+ , and there's no way I could afford that. Truthfully, I can't really afford the $500-ish that people have been selling non-running trucks for(if you can hunt them down), especially since the only useable part would probably be the frame.
  10. JeremyK5
    Aug 12, 2001
    549
    Indiana
    Actually, the rust isn't too bad on this truck. The framerail only has minor surface rust on it, except for the sections you can see in the pictures on the top of the framerail, which are depressingly thin.
  11. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    I'm parting a C30. In California :doah:
  12. JeremyK5
    Aug 12, 2001
    549
    Indiana
    Here's some more pictures of the truck (before i pulled the 12' flatbed off)
    Here's a picture of one of the springpacks, it has the 11 leaf main pack, with the 4 leaf overload pack. I've actually had the truck loaded down enough that the overload leafsprings were flat (twice), with no problems.
  13. JeremyK5
    Aug 12, 2001
    549
    Indiana
    Of course! :doah: It always seems to work out that way. I almost never see anyone parting out something I need in the midwest.
  14. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    If you're bound and determined to fix it, blast the whole thing, weld in new metal, reinforce, and thoroughly prime and paint it. Anywhere anything is sandwiched it's gonna rust.
