Repairing my Electric Tailgate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SkyScraper, Nov 8, 2002.
  1. SkyScraper
    SkyScraper Registered Member
    May 16, 2002
    43
    Southern Indiana
    Ok I bought a Motor and a the Regulator Transmission from a guy on here and they both seem to be perfectly fine. But today I got my new cable from LMC. I installed and the window went down no problem, but when I try to go up nothing happens. So I spent 2 hours trying to find the problem it seems to me to be the little switch up in the tailgate that is attached to latch. Do these go out alot?
    So I tried adjusting the tailgate so that the latch would close even tighter. Still no luck. How tight does that latch have to be? Does the new ones require the tailgate to close that tight? If so, I'm SOL because the latches won't go in further in. Any ideas.....any one? /forums/images/graemlins/confused.gif
    Thanks in advance for any help.
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if the switch has two wires on it remove the connector and put a jumper wire in the connector, if it only has one wire, jumper that wire to ground, if it works with the switch bypassed, the switch is faulty, if it still doesn't work, the switch isn't the problem.
  3. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    I had the same trouble last year and believe is or not wd40 cleared it up, I just sprayed the switch, I dont know if it made the switch open and close better or if it cleaned up the contacts, but it's working for me so far.
    Matt
  4. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I second 95 Silverado...I had the same problem of one way (new motor actually rolled the opposite of the old) window, and I bypassed it, then teh window worked. Bad cut-off switch, and it's right at the driver-side corner of the tailgate.
