Repairing rust holes not hole panels?
Discussion in 'The Garage' started by TheeColonel, Nov 26, 2006.
  1. TheeColonel
    TheeColonel Newbie
    Nov 26, 2006
    NC
    Hey guys I was wandering what the best way to repair the rust holes in my blazer were. I just want to cut the rust out and put down some sheet metal in its place. I was gonna use that jb weld stuff to hold the new pieces in place. Then put truck bed liner on the inside and out. What do you think?
    Hey! When is part 2 of the rust replacement gonna be done? I read the 1st part and have been waiting for the 2nd!!:D
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I would suggest a real welder, or just riveting the pieces in. Not sure if JB Weld is the best way to go. I have one last patch that we never welded on, which is the bottom front of the rear quarter, that I think I`m going to just rivet on...
  3. TheeColonel
    TheeColonel Newbie
    Nov 26, 2006
    NC
    I had thought about just getting a cheap welder from walmart or sears. Would that be ok. It doesnt have to be real powerfull does it? And is it 20gauge sheet metal I would need? I dont care how pretty it looks cause im just gonna spray over it.
  4. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    probably have to get a mig that'll weld that thin, probably with gas shield
  5. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    X eleventybillion. JB, glue, duct tape, bailing wire, etc etc is not the way you want to try rust repair. As for just fixing the actual holes...that is probably a fantasy as well. Usually there is a large area around each hole that is very weak and rust eaten too and should all be cut out and replaced. This weakened area is impossible to successfully weld or rivet to and will also need cutting out.
    Rust repair is such a sh!tty job, you may as well do it as best you can so you don't have to do it again a few months later.
    Rene
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Should be able to find a good deal on welders with Christmas sales and all!!! :D
  7. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    No substitute for a weld!...BUT!
    I'd weld or at least braze or rivet the patches on...especially if its a structural panel thats a critical part of the body,like one that holds the body to the frame,or seat belt bolts,etc..
    But I have seen a new panel adhesive made by the 3M company,that many body shops around here are now starting to use more and more..I've been told its so strong the repair panel or the old metal will actually tear and rip apart if you attempt to remove it once it is cured! :eek1:.
    They use it mostly on door skins and patch panels that are cosmetic,but claim they wouldn't be afraid of it on other parts..many of the body shop owners were very skeptical of this stuff when it first came about--but now use it a lot,instead of mig welding a patch panel on now..they were evidently impressed with its strength and durability..(though I wonder how it holds up to salt exposure after a few years!)..
    I still think welds are better,but with todays newfangled chemistry,I wont be suprised if the GLUE cars together in the not so distant future!...:crazy:
  8. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    You mean the Hummer, with a laminated aluminum body? :rolleyes: Scurrrrry stuff, that ... yep, glued together.
    -- A
  9. goldwing2000
    goldwing2000 Guest
    Lotus Elise is glued together, as well.
    If it's a non-structural panel (and I have to think it is, if you're replacing it with 20 gauge sheet), then panel adhesives are a good way to go.
    If you cut ALL of the rust out, you can seal the metal up to the edge of the glue line before applying the adhesive and it should be good to go forever. It won't burn away the paint like welding and it won't rub the paint off like riveting. It's cool stuff.
    You can check some out here: http://www.lord.com/tabid/3400/Default.aspx
    Most painter's supply houses carry it.
  10. burban89
    burban89 1/2 ton status
    Oct 16, 2006
    1,861
    Port Clinton, Ohio
    Ive used the 3M brand of adhesives, and that stuff is strong. We glued together two panels and then welded together two and put them in a frame machine. The welds broke before the glue did, and when the glued one pulled apart it tore the metal not the glue.
  11. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    20 guage??? I used 12 guage and worried it wouldn't be stong enough. Just something to consider. And weld for sure I would. Anyone can use a mig welder, well almost anyone.
