repairs before roll cage install?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by tp85, May 21, 2002.
  1. tp85
    tp85 1/2 ton status Premium Member
    Mar 14, 2002
    130
    Maryland
    My truck's body mounts are original, and greatly deteriorated. In some cases, almost complete missing. I guess this means that the body could be slightly sagging or misaligned?
    If so, then it would be foolish to install a cage before I replace the mounts. I'm assuming that welding/bolting up the cage would stiffen up the body in the wrong (i.e. current) alignment. Replacing the mounts after the cage could be a problem if the cage prevents the body from flexing back to the original shape.
    Is my reasoning correct?
    Are there any other repairs that I should consider before installing the cage (probably S&W)?
  2. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    You are right! Definitely get the body where you want it with doors closing nicely, and body seams straight before you put in the roll-cage. JT
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    the body is pretty stucturally stable so it wont move too much even if the body mounts are not there.but if you are going through the trouble of putting a cage in you want to have the body attached where you want it.i just replaced mine from chevy duty.polyurethane bushings are only 99 dollars for the complete kit.the hardest part is getting the old mounts and bolts out to put the new ones in.it took me about five hours to get mine in.the best way is to put a scissor jack in between the frame and body near the middle where the tranfer case is after you get the bolts losse to lift the body off the frame.at least this is how i did it.its the only way i could see doing it with out a crane
