Replace automatic hubs???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, May 2, 2002.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    My '88 has automatic hubs and a friend is offering to sell me some new Warn hubs for cheap... Question: What's the advantage of changing from auto to manual hubs? I have 5 bolts holding my stock ones in... are they very hard to change???
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Manual hubs won't unlock themselves when you go into reverse on the trail.
  3. The advantages are that manual hubs are mch stronger then automatic, although you will have to get out to lock them everytime. If you plan on doing any sort of hardcore wheeling then you will probably want manual hubs. If they are Warn Premiums (Gold and Silver) and he will part with them cheap then I woupld definitly go for it. As far as changing them if they are the same as changing manual hubs then it will be real easy. Hope this helps. Later 80K20
  4. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    Manuals are much more reliable in my experience. It's not thatmuch of a hassle to get out and lock/unlock. And the install is pretty easy. Hour tops.
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i still run my automatics for the time being and have not had any trouble with them...then again i dont do any rockcrawling just hit mudpits and the beach...but mine have held up well and are still kicking
    Later
