Replace m.c. after disk swap????
Discussion in 'The Garage' started by BamBamblazer, May 16, 2004.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    Has anyone had to replace their master cylander after doing a disk swap on a 14ff to get a good pedal? If so what was it from? Also i have read that you can adjust the push rod to the m.c. How is this done? is it right behind the m.c.? I guess just unbolt it and adjust out slightly then re-install? Any help on either subject will be great.
    p.s. I have ok brakes but the pedal is about 3/4's the way down before it starts to grab. /forums/images/graemlins/dunno.gif
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I put a mc off of a 65 vette with four wheel disc. I think I know it was an older vetter. Made the pedal a little better. Soft, but stops great.
  3. BamBamblazer
    Jun 24, 2002
    486
    So the pedal is still soft but the brakes are good? That may be the answer. I need to find something this week cause im goin wheelin next weekend. /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
  4. white-rhyno
    Jan 27, 2002
    942
    Yea, Its nothing like when i had drum in the rear but it stops great.
  5. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    What MC are you running?
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Doesnt it have to do with the proportioning valve? Not with the master cylinder.
  7. BamBamblazer
    Jun 24, 2002
    486
    stock k5 mc
  8. BamBamblazer
    Jun 24, 2002
    486
    as far as I know the problem with the prop valve is it causes the rears to lock up first. My rears don't lock, so I think i'm ok with the stock prop valve??
  9. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
    I just put in my D60 today, and with my stock 1/2 ton MC, it has a low pedal. It's because the piston in the MC is too samll to move the volume of fluid for the larger 1 ton calipers. A set of calipers stuck on the rear, will require a lot more brake fluid to me moved, that's why you're getting a low pedal, the caliper pistons don't acutate far enough to lock the brake until the piston in the MC has reached the end of it's travel. I would try switching to a 3/4 or 1 ton MC and see how that works for you. I asked what the differences are between the MC's in another post ( here ), but haven't gotten an answer yet. Hope this helps you some.
  10. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I just changed over to a 3/4 ton MC and it made the brake pedal firmer, and the brakes a bit stronger. Not bad for $22...
