Replace MAP sensor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BrianDamage, May 18, 2002.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    every once in a while, my '87 350 TBI will stall out..usually when I'm idling into a parking space or something...I also noticed it would stall out easier while in 4x4 ...
    so I checked my codes today, and I got a '33'...the maual says to change the MAP sensor, but has an asterick* that says sometimes it may be necessary for a pro to check it out first.
    is there anything I can check myself, or would you just go ahead and change the MAP sensor first and see how it runs?
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Check you vacuum lines.
    33-MAP sensor signal voltage was too high (low vacuum) for 1 second when throttle opening was under 2%.
  3. BrianDamage
    May 14, 2001
    753
    Alabama
    is there a trick to checking vacuum lines? is there anything you can do besides just visually inspecting them? is there a trick that you can use that might show a hole that your eyes might not catch?
