Replace one or both batteries?
Discussion in '1982-Present GM Diesel' started by Can Can, Oct 16, 2003.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The onset of the cold weather has caused my truck to show signs of a low battery at start-up. I was under the impression that one of the batteries powered the starter and one powered the GPs. If so, am I able to just replace the battery that powers the starter or is recommended that you replace both batteries at the same time?
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Replace both batteries at once if you can otherwise the older one will draw power from the new one then the power will go back and forth eventually discharging both batteries if there is enough difference in charge between the two.
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    The batteries are not isolated from one another and are hooked in parallel, so in effect they just become one larger battery. Replace them both, use the good one for your trailer or something...if you have a good one left.
    Rene
  4. Can Can
    15,552
    136
    Thanks lads. I still have to make sure it's not starter or alternator related before I go spend a couple of hundred dollars on two 1000 CCA batteries....... /forums/images/graemlins/tongue.gif
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Replace both batteries at the same time.
    I have to replace my alt tomorrow. Guess it don't like living in a case of mud!?!?! /forums/images/graemlins/rotfl.gif
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    yeah that is what I did for that same reason.
    The bad one will always ruin a good one.
    Just like people /forums/images/graemlins/rotfl.gif
    And the way to go is 1000CCA Optimas or equivalent in EXIDE.
    /forums/images/graemlins/thumb.gif
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I went with a pair of 1000 CCA AC Delco's...
    Rene
  8. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i have a similer question. one of my terminals just broke off my delco 850cca. they are both in fair shape. i get a new battery for free cuz its under warrenty. should i replace the other one too?
    or maybe run three batterys????? /forums/images/graemlins/grin.gif
  9. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    How old? And if you can replace both under the warranty, then id do both anyways.
  10. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    they should replace them both at the same time, explain to them what type of vehicle they are in. And remond them that only replacing one will cause them both to fail quicker than expected. Its worked for me.
  11. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    i like your thinking, i will call them tomorow.
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    He's right.
