replace rear tailgate electric motor. is my switch bad?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sinchphoto, Jul 20, 2002.
  1. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    i replaced the tailgate motor but only goes down. only once in a while the window rolls up. is my switch in the dash going out?
  2. ol_grayfeather
    ol_grayfeather Registered Member
    Jan 15, 2001
    68
    Around Spokane, Washington
    Does it go up all the time with the key in the back???? If yes then I'd say the problem is the dash switch.
    Dan
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Bad safety switch. Open the tailgate and look at the latch on the driver's side. Thats where the switch is hooked to. Take off the big access panel and the rod going from the handle to the latch. Now undo the four big phillips head screws on the latch and pull out the assembly. It will have some wiring plugged into it. A good cleaning or new switch and that thing will roll right up. You can also jump the two wires and have it work all the time.
