replaced axle stuff and now it's pulling
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Feb 21, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    replaced axle stuff and now it\'s pulling
    I replaced the inner axle bearings in each spindle and the seals, repacked other bearings too on my D44. Put it all back together and now it's pulling to the right. The only thing I can think of is at one point the drivers side caliper slid off the axle and hit the ground (I've got 12" ss lines). Maybe that jarred the piston in the caliper and it's jammed??? It tends to pull to the right going down the road but is very apparent when the brakes are applied. I was careful not to mismatch the tires so I don't think they come into play and I have checked air pressure, they're the same. Anybody have ideas on what could be causing this? Does this sound like a caliper problem?
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s/6superliftand33s.msnw>http://communities.msn.com/OffroadK5s/6superliftand33s.msnw</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Re: replaced axle stuff and now it\'s pulling
    I'm not familar with D44s, only 10s, but could you have over-tightened the spindle nuts on the wheel bearings? Could you have one bearing tighter than the other?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  3. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    The tires spun pretty easily after it was all back together. I've done this job several times in the past (minus replacing the bearings) without any problems. Oh, and do they make a tool to beat the axle bearings (inner spindle) out? I had to get creative cuz a punch was just glancing off the edge of the bearing.
    During luinch i took a drive and then felt the rotors. The right one was very hot but the left one was barely warm. I'm thinking it's gotta be a jammed caliper.
    Mudstud
    &lt;a target="_blank" href=http://communities.msn.com/OffroadK5s/6superliftand33s.msnw&gt;http://communities.msn.com/OffroadK5s/6superliftand33s.msnw&lt;/a&gt;
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt&lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by Mudstud on 02/21/02 12:51 PM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by Mudstud on 02/21/02 03:55 PM.</FONT></P>
  4. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Still need help guys. Any ideas? I've got this stuff apart right now and it all 'looks' good.
    Mudstud
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you might need new caliper bolts. or the bushings that the bolt go through. or your pads are uneven, bolts and bushings can cause this. also you might have a sticky caliper, bolts and bushings can also cause this.
    i guess what i am saying is check your bolts and bushings on your calipers.
    grant
    take me drunk, i am home
    www.geocities.com/seventy4blazer/parts4sale.html
  6. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Apparently, what you suggested was it, at least in part. After trying a few things including spinning the wheels without the brakes on it. After expanding the drivers side piston a bunch I reluctantly backed off the bearing just a tad on the passanger side and gave it a test drive and it braked fine. I'm happy, thanks for the assistance. [​IMG]
    Mudstud
