replaced blower motor, now won't start
Discussion in 'The Garage' started by southernblazer, Jan 15, 2006.
  1. southernblazer
    southernblazer Registered Member
    Oct 30, 2005
    6
    Mississippi
    I replaced the blower motor on my 94 Chevy Blazer (fullsize K1500, 5.7L) and now it wont start. The blower motor now works fine with the key turned, but engine wont start. It spins over but will never start. The battery has plenty of juice and I've tried jumping it, but I dont think that is the problem.
    When you replace the blower motor is it possible to damage the ecm? I started working on it before I realized the battery was still connected, I hope that didnt damage the ecm, or something else.
    The service engine light doesnt come on when you turn the key and I think it usually does. I wonder if it needs to be reset or unplugged. It was running fine before.
    Thanks for any help.
  2. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    You didn't by chance snag the power wire to the dizzy did ya??? Or maybe pop a fuse???
  3. southernblazer
    Oct 30, 2005
    6
    Mississippi
    fuses seem ok. all the connectors around the ecm look ok. the ac/heater now works fine with key on engine off, but truck just turns over. The service engine light never comes on, but I think it's supposed to come on for a few seconds when you first turn the key.
    I just wonder if I fried the ecm by not disconecting the battery beforehand.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've done that job on our '94 Sub. What a pain in the a$$ to get up under the dash! Check all of the wiring harnesses around the ECM. Disconnect the battery and then unplug each connection around the area you were working in and then plug them all back together. You might have just knocked something loose.
    If that doesn't work, then it's time to break out the wiring schematics and start doing some troubleshooting. :(
  5. southernblazer
    Oct 30, 2005
    6
    Mississippi
    thanks, I'll take another look at it tonight. I've checked the connectors and they all seem ok but I'll go over them again. I think there may be a ecm fuse under the dash as well as the one in the fuse box near the parking brake, I'll try to locate it to see if it is ok.
  6. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    My 87 Buick has a connector near the battery for ECM power.
    If yours is the same way, maybe it became disconnected.
  7. southernblazer
    Oct 30, 2005
    6
    Mississippi
    thanks, I'll check for that. I think there may be a seperate fuse or relay under the dash or hood just for the ecm, I'll check that also.
