replaced prop valve: No Luck!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mich89k5, Nov 1, 2000.
  1. mich89k5
    mich89k5 Registered Member
    Oct 30, 2000
    40
    Michigan
    I am clueless now!!!! I really thought that the proportioning valve was the problem,but apparently not. My balzer pulls to the right big time, and I have replaced everytninhg brake related except the booster. I just took my blazer for a test drive after replacing the prop. valve and master cylinder and the first 5 stops were pretty straight, but after that it was back to pulling to the right. I bench bled the master cylinder, so that is not a factor. Besides other suggestions to check I was wondering about the rubber button on the valve. I went to push it and it wasn't sticking out like I remember the original had. I'm looking at the old one right now and it doesn't stick out anymore either now that it's off the blazer. Is this just because it's not hooked up or does it only come out when the brake pedal is pressed? Please if you guys have any other suggestions besides the prop. vlave then let me know. When I had the balljoints replaced the shop said my bearings looked great. Could it be the spindle or rotor or hubs. I'm basically second-guessing everything that I replaced now, becasue I have replaced everything and still no luck.
  2. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Sorry Mich,
    I still think you may have a valve problem ... especially since you said you got 5 straight lines . You may have dislogged some trash, which may have blocked it again.
    Not sure what to do at this point though. Maybe someone else can help.
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Check the wheel bearings yourself. Also just cuase they look good does'nt mean they are adjusted right. On my buddies k-10 the pin on the nut was broken off allowing it to not lock and come lose. Pads could also be contaminated.
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    could the rotors be warped in a weird way, or the spindle bent? have you had it aligned?
    Knife.
    knife.coloradok5.com
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Another thought - could the calipers be "sticking"? Have you ever had the calipers rebuilt?
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
