Replaced Rubber body mounts w/poly now gearshift indicator off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by opfor2, Jan 30, 2003.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Hi All,
    I replaced all of the rubber body mounts with poly mounts from energy suspension. Now the gear shift indicator is off. Inorder to put into overdrive I have to have it between Neutral and Overdrive. What happened ? Do I need to adjust the TV cable ? All I did was replace the body mounts.
    Dan...
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Think about this: The shifter is attached firmly to the steering column, which is attached firmly to the body. The other end of the shift linkage is attached firmly to the transmission, which is attached to the frame. The new body mounts probably changed the distance between the body and the frame just a bit, so the length of the shift linkage needs to be adjusted to make up for the difference. Check the linkage and you'll see that it has places that can be adjusted by just loosening a single bolt, usually at the lower end of the rod that goes down from the column and/or where it attaches to the tranny. /forums/images/graemlins/thumb.gif
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    DO NOT TOUCH THE TV CABLE. Changing mounts will not affect it. Like HarryH3 said, the linkage going from the steering column to the tranny is out of adjustment now. Down by the tranny input selector shaft, there should be a metal "canister" with a hole in it that the shift rod from the steering column goes through with a locking bolt on the end. Loosen the bolt (adjust the shaft one way or the other) and try it. Adjust it until it's correct. PB Blaster may be needed if the shaft and assembly are corroded.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    There is also a clip o nthe steering column that can adjust the indicator
