Replaced wiper delay module on 85 K5... still no good
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tungsten, Feb 23, 2004.
  1. tungsten
    tungsten 1/2 ton status
    Oct 29, 2003
    104
    Nashville, TN
    Well I replaced the wiper delay box (bottom of the steering column) on the 85 K5 and still don't have intermittent wipers. Either full on or off, but nothing in between.
    Logic tells me that the switch on the column is probably bad too. The delay box obviously had a blown diode in it, but maybe the switch got zapped with whatever surged through the box... or at least that's my theory.
    Is there anything else in the system that would cause the intermittent wiper settings not to work? Anything in the wiper motor itself? Or are the only two components the delay box and the column switch?
    Thanks.
  2. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    What happened before the intermittent wipers stopped working? Did the wiper motor get wet?
    I had a similar problem on an '89 Sub. Just like you've done, I replaced the module under the steering column and I still had problems. I ended up having to replace the windshield wiper motor before things were back to normal again. Based on my experience with a problem similar to yours, I'm going to say you will need to replace the wiper motor.
  3. tungsten
    Oct 29, 2003
    104
    Nashville, TN
    I have no idea; I inherited the Blazer and it came complete with a bucket o' problems... the delay wiper being one of them. /forums/images/graemlins/smile.gif
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Mine would do this as well. I searched on here for a while and came upon a pretty good tip. I had tried everything on the motor: cleaned the contacts, cleaned the insides, adjusted the little spring that makes contact for the park aspect to no avail. Anyways the post said to adjust the bolt that comes out of the top of the motor. I fiddled with it and now the wipers rarely mess up. /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  5. K5Glazier
    K5Glazier 1/2 ton status
    May 29, 2003
    220
    Chandler, Az.
    Here is my $.02. Mine were working fine, After I disconnected the plug at the washer dispencer, I lost my intermitten wipers. I had either on or off, like yours. Could your problem be at this connection. Oh yea, I never did go back to plug the washer dispancer back in, so I'm not so sure that this will cure your problem, but.........
    Good luck,
    Joe
  6. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    The washer motor is part of the delay circuit. It must be there and it needs to be close to the factory resistance. If that is good and the delay box is alive then the wiper motor most likely needs replaced. The switch is only a variable resistor. If it were bad the common failure is that the variable speed is not consistent.
    Mike
  7. tungsten
    Oct 29, 2003
    104
    Nashville, TN
    Mike
    Ah HELL. The washer motor and bottle and everything else is gone from this truck. My grandfather apparently pulled it at one point and never replaced it.
    I guess that answers that! /forums/images/graemlins/tongue.gif
