replaceing ball joints
Discussion in 'The Garage' started by 4x4k20, Aug 19, 2002.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    mine are worn out on my 84 k5 how hard are they to replace?what special tools will i need?
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    I know this has been covered before, so do a search.
    You will definately want a ball joint press. You can "borrow" it from Auto Zone for $100 deposit or buy one from Harbor Freight for around $50. Make sure you have a hub socket, a torque wrench and you might also want a ball joint adjuster socket. You can get the joints apart with a big pickle fork and a big hammer (at least 3lb)
  3. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Harbour Freight had the tool on sale for $20 last time I checked. I had mine pressed out at the local Midas shop for $19 - I found the tool for sale after I had them pressed out.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    get the ball joint tools makes a lot of difference. I got mine from harbor frieght also you'll need hub socket, spaner socket(for the upper ball joint), and a torque wrench. make sure you put some grease on the ball joint tool threads.
    ARQ.
  5. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I dont think they have harbor there like we do here! and hello neighbor /forums/images/icons/wink.gif
